ok guys need some wiring help
joe f350
ca
ok guys need some help dose some one know. what these burnt wire are and where they do to so. I can replace them my old plug harnes plug on the chassis side all the wire got brittle and snap of flush. so went and got this new plug at the junk yard and i notiected these wires. i would like to run new ones just to be safe.
You haven't a clue what area it goes in? Is that the plug that plugs the wiring in on top of the engine over to the solenoid?
joe f350
ca
i know where the plug goes just wonderen there the burnt wires go to so i can just run new wire in ther eplace
ifrythings
BC
If that is the main engine harness plug the wires should be
engine temp - red/white : from temp sender to gauge
oil pressure - white/red : from oil sender to gauge
ignition - red/green : from ignition switch
note: this wire will have a 20ga. blue fusible link on the truck side, then turns back into red/green on the engine side plug (assuming someone hasn't removed it
glow plug relay - purple : from gp controller to gp relay
ground - black : from gp controller to ground
LH gp's - orange/white : from gp relay to gp's
RH gp's - orange/light green : from gp relay to gp's
overheat switch - red/black : from temp switch to warning indicator
The first pic appears to be the trailer wiring harness under the dash but this looks like its a pic from the engine compartment. Still think its trailer brakes connection.
Does your GP controller work or is it a push button? My bet is the burnt wires are something glow plug circuit related. That looks like a key on 12V source that has been tapped off of for something. Going to have to chase it and see where it goes but yeah... that seriously needs fixed.
I'm not sure what that connector is. The two big wires with ring terminals almost make me think thats the truck half of the engine harness???
joe f350
ca
i think its the igtion cause the po has the gp on a push buttion set up for the glow plugs and and anther buttion for the starter
Oh wow... you probably have a lot more problems than you even realize yet. Depending on what your sanity is worth to you and what level of "back to factory" you are looking for, you might well be ahead to just go find an entire underhood wire harness. Hopefully the cab and dash harness aren't cut up too bad but based on what you have shown thus far, I wouldn't bet on that.
I wish you luck. I hate cleaning up messes made by PO's that don't know what they are doing.
joe f350
ca
im thinking of just running new wires to the ignition switch cause i peeled back some tape of the wireing not putry at all
joe f350
ca
know i wish i had a digream so i knew where to run the wires to dose any budy have one
Search around. I think autozone has a bunch of wiring diagrams on their website. I think Oldbull88 has posted those before for different trucks. I keep forgeting you are an 85. There may be a lot of ugly going on under the hood depending on how they grafted the wire harness in to deal with the change from sealed beam lights and such. The 97 wire harness would be a bit different for sure.
joe f350
ca
well i found half just not the half i need keep find glow glow plug half but not the only chaiise side well if i can get a answer buy the end of nith im gona have to peel back the tape and dive in
ifrythings
BC
These may help, let me know if you need any of the sub sections
joe f350
ca
i fry things ur the man thank u i endeed up pull the dash but this help me big timeit help me patch some other areas
Lance
Staff online
