Oil temp, how hot is too hot?
phazertwo
Die Summer DIE!
Crawlorado!
I have heard of people having their "oil temp" light come on when climbing long hills. Well, I live near Denver, and I need to be able to tow my Toyota crawler over I-70 to get to Moab! I am concerned about oil temp, so I figured I would through a oil temp gauge. But how hot is too hot? At what temp does the light come on?
Also, is there any after market oil coolers that do a better job than the stock one?
TIA
PZ
Oil temp lite???:dunnocookoo Who told you about that. These motors don't have any lites for oil temp but.... There is a coolant overtemp lite... It comes on at 242 degrees and usually is just about the time you ruin the motor. I ran my first rebuilt motoroil temp past 330 degrees because I lost all my coolant when a freeze plug let go that was installed wrong. Once the coolant is lost nothing is telling the temp senders whats going on. I had installedan oil temp switch in the oil pan so I could watch the temps. They usually run about 10 degrees higher than the coolant temp... Till you pull heavy or are on a grade. Then 240 to 260 are common...
FordGuy100
Silverton, OR
The IH trucks have oil cooler lights. I remember a guy posted about his coming on, when pulling grades.
phazertwo
Die Summer DIE!
Crawlorado!
interesting, I must be special, i totally thought there was a oil temp light in the light cluster.
I have the gauge already, so no point in wasting it!
Thanks for correcting me!
PZ
pedro_8149
7.3L Remote Turbo
Terrace B.C. Canada
i also have an oil temp gauge but no idea as where to install the sending unit for it? where are you putting yours, pics would be a good help.
