Dont know what it would take to ruin one, especially if it doesnt lose coolant.
Have seen 265-270 (on real temp gauge, and verified with temp gun because I didnt believe it) for 10 minutes or so several times. This was pulling a pass several times over a couple summers.
the heck were you doing?
and for sure you have something wrong with your rig, likely a fan clutch
as for the op, 220* is not outside the realm of normal, however if you arent hearing the fan clutch lock at 220* i would absolutely suspect a bad fan clutch.
i would replace it and retest
@hacked89
what do you have for double oil coolers? what is your setup? 285* is absolutely insane
why are you ok running that hot, there is absolutely no reason, need or such that you should be running that hot.
oil temp will probably be 300* at that point and the rate at which even modern oil degraded at that temp is astounding.
With my upgraded fan and clutch i have yet to get it over 220* coolant and 225* oil temp when trying to get it hot climbing the Continental divide with a small trailer on, in 90* ambient temp.
or with 13k behind me and water **** on, However some of my customers have been able to hit 235* with my fan and a good working fan clutch, but that was also a 12.5k lb fifth wheel up a 6% grade in Arizona in the summer ...
