datkinsonsr
After I got everything cleaned, I installed the new seals as per the instructions, and pressed the pieces together. It took way more force to do this than I would have thought. No leaks when I first started, But after 5 miles, Lost pressure. Coolant is now full of oil. No water in oil as far as I can tell. This time I will install the seals on the sleave and press one end at a time. I have never had this much trouble with seals before this. Any one else done this recently?
