HammerDown
I really gotta get this fixed (in Spring )...starting to drip-drip in the driveway.
The oil cooler is great fun! I pulled it apart, jacked up the motor, then still had to pull the manifold again to get it out. When I put her together she leaked like a seive on the water side. I had to pay someone to fix it after all that. If I had to do it again(I pray I won't anytime soon) I would pull the driver's side exh. manifold straight away and leave the engine mounts in, then I'd pull the power steering pump assy and I would make sure the mating surfaces where the front and rear headers mate and the ones on the bundle itself were perfectly clean and shiny(I think this was where I screwed up, got too much in a hurry and tried to cheat. Some sort of gasket sealer may even be appropriate here, not sure what the consensus is on that.
Details Travis it's all about details...can ya make sure about the "enough room" dealeo so I'm not cursing you out when I'm pulling the manifold and inside fenderwell off!Don't know how much room there is compared to a 4x4 but in the E there was enough room to work.
