And I bought the dp but it's flange is too small for the gtp38, where can I find a vband flange only for the gtp38??
e-bay.
not sure about the 1.10 housing. IMO this should be taken care of after the majority of the project is done.
get her running first! but its your truck do whatcha want...
but i would want to compare the 2 personally, and swapping a turbo housing is a hour or 2 job.
there are trailing arms on the 05+ SD coil spring front ends.
need to make sure you fab that shat correctly...
gives a really nice ride.
if you want to do leaf springs, the hangrs are simple-ish
