mblaney
I thought I would post some pictures of my stainless brake line kit from Inline Tube. I had replaced some lines maybe five years ago and some had already rotted. After two failures over the summer I decided to get a full front-to-back stainless kit. This kit was $195. I didn't bother taking pictures of the lines installed, they are just brake lines after all. With this I also replace all flex lines, caliper rebuilds, new wheel cylinders, plus brake parts.
Here is full kit.
Close up of the bends.
The only 'problem' I had is that the bends didn't necessarily match the originals "within 0.005" as advertised. This was never a problem though, everything fit fine even if minor tweaking was required. This pic shows that the bend (coil) is way different from the original. Still worked fine though.
I had one problem; the NAPA wheel cylinder (one of them) was designed by an idiot. There is nowhere enough clearance to get a wrench or socket on the bleeder. I had no choice but to use a small pair of vice grips to get the brand new bleeder out
I put it on my drill press and used an end mill to open it up a little. Funny, the other side was fine as is. ***?
Here is full kit.
