Need a IP Adjustment Tool
NeverHave-I-Ether
Texas
Howdy!
Anyone have the special tool or a homemade one that I can borrow? I'd make one myself but don't have a grinder or welder! (On a list of things to get..)
Thanks,
Never-Have-I-Ether
gandalf
Senior Member
CA &/or Maine
Those adjustment tools seem hard to find. Many of the IPs will have a 3/4 inch fitting sticking out toward the front of the truck. If your's does, all you need is a normal every day open end wrench.
NeverHave-I-Ether
Texas
I'll double check, I had read that there's a hard to reach bolt that a funny angles wrench is required for....will look at it
Never-Have-I-Ether
Cubey
Van dweller
gandalf
Senior Member
CA &/or Maine
Never-Have-I-Ether
That hard to reach nut in on a stud coming out of the rear of the gear tower, clamping the IP in place when you time it. What I'm talking about is on the IP itself, on the forward facing section. You can see it in this picture. It's perfectly square, sticking out a bit.
TNBrett
Middle Tennessee
No welder needed for this one. You can easily modify a 9/16” wrench with a propane plumbers torch, and a 4-1/2” angle grinder from harbor freight. You’ll spend less than you would on the “proper” tool, and you’re increasing your arsenal for other projects.
NeverHave-I-Ether
Texas
Timing your truck, huh? I'm jealous!
My timings at 12° and really needs to be fixed. Hard start. Im hoping this is my fix.
I'll take a look at that cheap wrench. I don't see why it shouldn't work, they look similar...
Never-Have-I-Ether
You know, I've been reading this thread since it started thinking to myself, " when I changed my IP, I didn't have to make a funny wrench.....I don't think I did..... maybe I did. They sure seem adamant about a wacky wrench." But IDIbronco is right, that's how I did it. Of course I was changing the pump not timing it. I just put it back on exactly like the one I took off.
tke395
