N/A IDI Turbo Conversion
BlueHound
Minnesota
Does anyone know what turbo the banks kit uses? Specificly the turbine inlet pattern.
BlueHound
Minnesota
Because I’m trying to decide if I should go with the banks kit or spend the extra money to go with the stage 2 kit from R&D IDI.
BlueHound
Minnesota
What if I get a different waste gate, Or a different turbo?
By the way do you know what the turbo inlet pattern is on the turbo?
Thewespaul
Bulverde, Texas
The banks turbo is internally wastegated so you would have to replace the entire turbo, many people have run the banks kit with upgrades turbo but I prefer the R&D base to build off of, the banks is an older design
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
turbo flange is t3 on all turbo kits offered for the idi, other than r&d i belive. he may have a t4 on the larger kits
BlueHound
Minnesota
So Any T3 flange turbo’s could go on a banks kit or I could put on an adapter plate for a T4.
Macrobb
North Idaho
For good psi, I was really impressed with a S360 with a .63 t3 exhaust housing on Banks piping. It would push 35 psi without any strain on 110cc of fuel; and it felt like it had a lot more to offer.
The .83 housing on the same turbo...sucked. would barely spool.
pwillis
