well I have a question, my truck actually runs cold. Im wondering why my needle lives on the N in normal. It used to be straight up and down but no matter what now it lives on the N and knowing that heat is a diesels friend I am concerned. my coolant is full
the issue i have is from mods i have done, i have a dew eze big bale loader on this truck, i had to add a crank pulley to accomodate the hydraulic pump to operate this, when i added the crank pulley my original fan would not work so i added electric fans and removed the original. the whole system is great till outside temps get above 80 then my cooling system just doesn't cut it, cruising down the hyway unloaded is no problem but if i'm pulling a load temps get up to 205-210 pretty easy
