that y’all might like this, no more trying to lock the water pump with a flathead to keep it from spinning.
I did this same thing with my fan replacement! Works great! I had the pulley holding tool but this idea was so much betterthat y’all might like this, no more trying to lock the water pump with a flathead to keep it from spinning.
Hmmm maybe no, definitely not factoryYou mean those aren't high speed cooling holes?
A NOS energy drink would seem more appropriate there but still good +10 hpThis is gonna be a great builder I can tell alreadyYou must be registered for see images attach
I can relate. I pulled the collector pipes off of my parts truck last month. I was thinking that the engine would go on the stand shortly for a rebuild, but when I dropped the exhaust I got soaked with water. Apparently the cowl seal is worse than it looked and the exhaust was full of rainwater.This is gonna be a great builder I can tell alreadyYou must be registered for see images attach
10/10 easiest way to remove IDIs starterYou must be registered for see images attach
Well in this case it was never installed on this one, guess someone thought it was unnecessary weightI bet it still sucks to get to the top bolt......
