x2 on the IDIs all drinking some oil, and the 6.9s are definitely the worst of the group. Valve stem seals shrinking/hardening will just add to the oil consumption, which by the way is worst on start up. So if you're 6.9 is getting some oil past the valve seals, and it's mostly on startup, I bet it just looks like "a little more smoke" on startup.
As long as your oil and water aren't mixed, I wouldn't worry about adding a little. Your coolant leak is most likely external, you just haven't found it becasue it's small and most likely getting burned off something hot. Your oil consumption is what I would call normal. If it bothers you enough, tear off your valvecovers and fix it, otherwise just add a quart when necessary.
just my .02
just my .02
