squeekyM
Hi Everyone,
About 2 weeks ago I changed out my thermostat, radiator, and all hoses. Things were going great, but I began to smell coolant every now and then. Never could find a leak, and have doubled checked the hoses... nothing. On Friday, the truck sprung a very small coolant leak that would drip from ??? down onto the starter. The leak was very clean coolant, no mix of oil or anything else. Where would this be coming from? I checked the block drain plugs, dry. The block heater area was dry also. It seems to be coming from behind/rear of the block drain on the passenger side of the block. What is in this area that could leak, the oil cooler?
How should I deal with this? Thanks in advance, take care.
- Jerry
- Jerry
