If it sounds like a rattling exhaust pipe, chances are it is. Most likely the downpipe worked it's way loose. Did you use a section of flex pipe between the downpipe and the main section of the exhaust? if not, and you have rubber engine and tranny mounts, the DP easily could have walked out enough to rattle against the firewall making a heck of a racket. I had the same thing happen when I first mounted mine, except mine did it within 2 miles. I turned the DP around for better clearance and cobbled up a different shaped mounting bracket that held it in better.
Even heavy frame flex could have popped it out if you've been in some squirrily places.
look closely at the oil mess, is it coming from the area between the turbo and the pedestal, where the O ring is or from around the grommit in the valley pan.
If it's too hard to see the oil till it's a big mess, you can get some UV dye like for AC systems, except get the stuff for use in engine oil, probably take 2 bottles for one this size, and run it a little with that and get in there with the UV light ( don't forget the UV safety glasses ) and a mirror and you will be able to clearly see the smallest leak and be able to tell exactly where it's coming from, it will glow bright yellow .
-----Robert
