Simp5782
SNOW TACKLER!
I will add that how i mounted the IC is a lil unusual. I used some scrap steel and made a raised cross member from frame to frame. I then drilled holes where the lil alignment dowels on the IC were.I put a slight mig weld on the crossmember on each frame. I used a die to thread the dowels and i used rubber bushings on top and bottom along with a flat washer and nut. It seemed to be pretty snug but i used the lil fan install kit things from hayden i had laying around for a lil extra snug fit so it wouldnt vibrate.
