pontoonrob
working on my truck over the weekend,Installed a glowplug controller. Went to start the truck and no power to the controller happened. Then turned the key to off and truck remained running! rats!! so I am assuming this is a wiring problem in the wires going down the column. \Ordered a new turn signal wire harness from Rock Auto. In the meantime what wire shuts off the engine? gong to wire up a few temperary switches to run the truck. Already have button to energize starter,also have switch for fuel pump,so what else is needed? switch to injection pump? and?----Rob
