Ataylor
Just curious if anyone has a gauge on their manual transmission. How warm do they run while towing? ZF-5 or T-19
Just curious,
Thanks,
Archie
Just curious,
Thanks,
Archie
One thing to remember about these transmissions.... they are alluminum. They are alluminum HEAT SINKS. The will suck heat right off of the motor, so you can expect them to get to at least water temperature at a minimum on lenghty trips.
Also, there are some finned aluminum "blocks" that replace the PTO covers and provide a couple extra quarts of lube capacity, plus also being heat-dissipaters; those are very popular on the Dodge sites, yet I seldom see mention of them on here.
Don't have a manual tranny, but just read in a 1938 Popular Mechanics mag. that putting a rubber hose over the stick will absorb the gear noise. Might even insulate the heat from it. Good Idea?
can't hurt...but a ZF shift stick is already a composite metal/rubber sandwich.Don't have a manual tranny, but just read in a 1938 Popular Mechanics mag. that putting a rubber hose over the stick will absorb the gear noise. Might even insulate the heat from it. Good Idea?
