Help Needed with 7.3 IDI - Starts up then Dies, no start now
scjarena
Houston, Texas
I have a 90 F350, 7.3 IDI, for the past year starts right up no problem. Over the past month, I noticed it getting a little harder to start, had to crank on it a few more times. Then last couple weeks, it would start ok, then die out right away, after some cranking it would finally start. Yesterday, started up, died, now doesn't want to start. Any help diagnosing the problem would be appreciated.
Batteries are still good, I think glow plug system is fine. I don't think it is puffing black smoke while starting so I'm thinking fuel problem.
scjarena
Houston, Texas
I'll look over the return lines, but I don't remember seeing any fuel leaks, at least around the intake area and around the injectors.
quickster
S Carolina
You don't always get leaking fuel. The lines pull in air. If they are braided, look for darkness or feel them for brittleness. I don't like braided myself
quickster
S Carolina
I read a while back that the shorter the run time before it dies, the closer the leak. So if it runs a few seconds, the leak should be up top.
miles1400
Macungie PA
air intrustion. alot of people recomend checking the return lines, also check the hard lines and the filter head aswell
scjarena
Houston, Texas
I found a loose return line near the filter. Fixed it, bled some of the injector lines and it started right up. I'll let it sit over night and try it in the morning. Hopefully that was the problem. Of all the different old school diesels I've owned the IDI seems to be the most ****** about air intrusion.
papadiesel
Indianola, IA
Mine were not wet and looked fine, they can suck air and not leak. I replaced with quality set, start went from 10plus seconds to 2-4 seconds.
Rayfish
