tjsea
So @laserjock I've kind of had a sudden thought come to mind. We talked the other day about your coolant filter and turbo returning to a separate port on your water pump. My thought was that with them in that extra port that too much coolant was bypassing the radiator and just circulating around in the engine. My thought to test the theory was to put a tee in the upper rad hose and return to there for testing purposes. Yes it will take longer to warm up initially, but it could prove my theory. So I'm laying in bed tonight (cause that's where all the best ideas come to mind lol) and thought this could also be the reason your fan clutch isn't kicking in. The fan clutch engages based off of radiator temp, but if the volume of hot water isn't making it to the radiator the fan clutch isn't going to kick in. In essence the engine is getting hot from circulating too much hot coolant within the engine and not making it to the radiator to be cooled off. This still doesn't answer the rpm based part, but to me it answers why your fan clutch isn't kicking in. Not as much volume of hot water through the rad = less heat being shed through the radiator and less hot air hitting the fan clutch to engage it.
