What brand of plugs are you running and how long are you holding them on for?
I recently converted mine to a push button and with the ZD-1 glowplugs, 8-9 seconds gets them hot (confirmed this with a bench test) and the truck fires right up without a miss.
I also like that when I start it hot, or even luke warm, I don't even use the plugs; but the controller always cycles them a bit even when hot. Which makes no sense as the plugs don't even remotely get hot from a 2 second cycle that the controller was feeding it
