SKimballC
Justin, I was thinking about that on the way home last night. I would disconnect the batteries and remove the sheet metal screws holding the fuse box and see if you can swing it down or to the side and try to get a drill in around there. That would be the best spot if you can get in there. Also, since you are going to have to lengthen the wires on your 2 temp senders, I would cut the connectors off so that you can drill a smaller hole just big enough to feed the wires through, then you can put the connectors back onto the lengthened wire instead of feeding them through the firewall.
Oh, and put some coolant in your empty expansion tank.
