1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Front cover removal
Discussion in '6.9L IH & 7.3L IDI Diesels' started by Jonathanbwata, Feb 3, 2019.
  1. Jonathanbwata
    Jonathanbwata Registered User
    23
    Feb 3, 2019
    Weed, CA
    Hello I have a 94 cclb 4x4 roll a long package with e40d trans and 7.3 idi in it...
    The 7.3 idi took a shit so I got a free 6.9 idi out of a school bus and it had manual Trans on it and the block I believe is a 86
    I swapped in the 6.9 motor and noticed the front cover doesn't have a place for tac sensor which is not good because e4od needs tach to shift right?
    And I was wondering can you remove the covers without removing the gears I have a deadline to get this bitch going again Cuz I'm using my bosses shop and we gotta big job coming in on Wednesday lol....I'm a Welder and want this to be my work rig and hope to carry a flatbed and Lincoln on the back..thanks for the help
  2. Clb
    Clb Another old truck Supporting Member
    3,758
    474
    Mar 1, 2013
    nannyfornia
    Yer in trouble...
    i cannot dial ya in to this now.
    try a search for do not pull the cover when changing ip
  3. Jonathanbwata
    23
    Feb 3, 2019
    Weed, CA
    I know how to take ip off and and the 3 bolts under the cover hold it to gear so couldn't I just unbolt front 3 bolt that mount pump and pull the 4 to the cover
  4. sjwelds
    sjwelds Full Access Member
    1,231
    170
    Dec 30, 2013
    Central KS
    Should work, just make sure the gear doesn't jump time
  5. austin92
    austin92 Full Access Member
    935
    259
    Jul 20, 2016
    Brazil. IN
    I want to add a tach to my 83 so I asked a similar question. I was told it can be done, just be carful not to move the gear. If you do move the gear, you can find tdc on cyl 1 and get the gear with in one tooth. It’ll be a bitch if the gear moves but it’s doable. You could always swap in a zf5 :)
  6. Jonathanbwata
    23
    Feb 3, 2019
    Weed, CA
    Is there a way to tell if it does move or not and any insurance to make sure it don't move.... feel like the ip will lose timing when I take the 3 bolts in front out
  7. Jonathanbwata
    23
    Feb 3, 2019
    Weed, CA
    And yes I wish I had a 5 spd I don't care for tach on auto trans but stupid e4od needs it I'll attempt taking the one off old motor first and them I'll do the new one
  8. Clb
    3,758
    474
    Mar 1, 2013
    nannyfornia
    It's a real pita with big time ah geeze possibilities, know the issues before you dive in, I forget what all could be an issue.
    Someone has done it, and should chime in ....
  9. Jonathanbwata
    23
    Feb 3, 2019
    Weed, CA
    I hope for an answer lol I really don't want to mess up the timing or if there is another way around not using the tac
  10. Clb
    3,758
    474
    Mar 1, 2013
    nannyfornia
    E4od stand alone programmer?
    I got nuthin on slushbox's...
  11. Thewespaul
    Thewespaul Supporting Vendor Supporting Member
    7,375
    5,427
    Jul 27, 2015
    Bulverde, Texas
    The wiring is doable, Id recommend buying an electrical service manual for your year truck and following that to setup your truck with what it needs. If you dont have the computer and the wiring harness for the transmission already then you need to get it out of the parts truck. I made a standalone harness from scratch to put an idi and e40d in a 43 ford cabover project, it worked but it is more wiring than I intend to ever attempt again.
    IDIBRONCO likes this.
  12. IDIBRONCO
    IDIBRONCO IDIBRONCO
    3,587
    1,944
    If it was me doing this, I'd be pulling the front engine cover off (the one behind the water pump). That's the only way that I'd feel comfortable enough doing this job. It's a lot more work, but you can guarantee that your gears are still in time this way. Also, yes your pump will no longer be in time after you pull it. Nothing that can be done here, just the nature of the beast.
    Scooch and DrCharles like this.
  13. DrCharles
    DrCharles Full Access Member
    831
    441
    Dec 18, 2017
    West Plains, MO
    Also you can reseal the front cover while you're in there. It is SO much easier to work on an engine when it's not in the truck ;)
    Edit: oops, looks like it's already in the truck! Still probably worth it.
  14. bbjordan
    bbjordan Snow Monkey
    1,269
    245
    Feb 24, 2011
    Calgary Alberta
    Yes, you can change out the cover. It's not that big a deal.
    Before you take the IP off, do yourself a favour and line up the timing mark on the crankshaft to TDC. Take the lemon cover off and make sure the dowel pin for the IP is in the 4 O'clock position. With that done, even if something goes sideways, you'll be in good shape.
    Worst case, if the timing gear jumps, follow the instructions in the link below. You'll be able to skip the first part, cuz the engine will already be at TDC. :)
    http://blackwire.com/~bjordan/Tech/Timing_the_6.9-7.3_IDI_101.pdf
    Good luck!
    Macrobb likes this.
  15. Jonathanbwata
    23
    Feb 3, 2019
    Weed, CA
Share This Page
