Ok fellers so here is the scoop. I checked all pistons and they consistently protrude .020 thousandths from the deck (give or take one thousandth). What an awesome tool to use btw. Sooo, these numbers seem to be within spec. I have talked to Brian and the machinist about this issue, and we came to the conclusion that it might be best to recess all intake & exhaust valves another .010 in the head. Yes, doing this will throw the valve recession slightly out of spec, but the machinist nor Brian thinks this will cause any problems aside from a very minor decrease in compression. We feel that by doing this, pistons will no longer hit the valves. We also think that the spring tension might be an issue. Maybe the extra lift with the torque cam is causing interference due to the springs being weak & not being able to shut valves quick enough
. And to solve this problem, I ordered the comp 910 springs to install. If I could help it, I would rather not pull this engine out to mill the pistons down.
But I still have a question. Why did the drivers cylinder head with the 4.795 measurement have more valve contact than the passenger head with a thickness of 4.800? Valve recession between heads was fairly consistent.
