The ZF5 is a good transmission if it isn't abused. I'd much rather have a ZF5 than an E4OD. I'd pick that ZF 10/10 times over the E4OD........... hands down, especially for towing/hauling.
Heath
Heath
With all due respect, care to elaborate?The ZF is only a little better than a stock E4OD.
The jury is still out on what I'm going to do. A good friend who has an IDI that he changed from extended cab to crew cab is coming over on Thurs to take a look at my project and provide some guidance. Now my issue is, do I move my cab, bed, front end, motor, and rear axle over to the donar truck frame and use the existing ZF, Xfer, and drive shafts, or do I modify mine to add the front axle from the doner, x fer case and drive shafts? Or, do I put the interior back together on the doner, move my bed, motor, and front clip.
Given that sort of use....yeah, I could see any transmission having a shorter lifespanPush a ZF hard. The little stuff. Broken shifters. Rule of thumb Don't force it into gear.
The syncros. They make some interesting sounds when speed shifting.
Best one we had. Something broke while towing a hefty trailer. We never opened that sucker up. All I know is the driver hit second gear. Then a nice sharp crack followed by what sounded like a bomb going off.
Best one came from a good friend. he ended up dragging home a 99 450 roll back with load. Broken pilot shaft. Can't blame the transmission on this.
New driver panicked on a hill, side stepped the clutch.
IMHO it'll be easier to swap the body parts over to the 4x4 chassis than it will be to graft the axle to your 2WD chassis. Depending on what shape the sheet metal's in, you'll probably be ahead just transferring the entire body over, but which cab/interior you want to use is really a matter of personal preference IMHO...The jury is still out on what I'm going to do. A good friend who has an IDI that he changed from extended cab to crew cab is coming over on Thurs to take a look at my project and provide some guidance. Now my issue is, do I move my cab, bed, front end, motor, and rear axle over to the donar truck frame and use the existing ZF, Xfer, and drive shafts, or do I modify mine to add the front axle from the doner, x fer case and drive shafts? Or, do I put the interior back together on the doner, move my bed, motor, and front clip.
