Titojeep
Thanks to all who have helped in the past. I've been off the forum for a while dealing with life and work. I'm back on my feet and back to having fun again.
Question: I have a 93 F350 DRW CC 2 WD with a E40D tranny. I have a donor 92 F350 5 speed ZF5 S42 tranny, 4X4 with the DRW spacer set up on the axles. After having read a few articles on the internet, I can't find any write up's on this forum? Can someone chime in with the exact thread name? If not, then my general questions are as follows:
1. Can I use the X fer case from the donor truck with my E40D? Is it a matter of tail shaft removal and using the drive shaft from the donor truck?
2. The frame is different up front where the spring mounts. What are my options?
3. I understand that I'll have to sweat a little to grind off the rivets for the spring brackets. I also understand that I'll have to do a bit of fabrication for the track and sway bar mounts. Any other feedback on this part?
I'll go ahead and note, that I'm interested in parting out the rest of the truck as well. i.e., motor (7.3 IDI 300K), tranny, front clip, cab (crew) with all 4 doors, glass, panels, rear axle, and main frame.
Thanks in advance.
Titojeep
Dacula GA
Thanks in advance.
Titojeep
Dacula GA
