Is there any way we could get a 'sticky' set up with build ideas for different combinations? And part numbers?....or...do we already.
Thats kinda what I was getting at. It would be nice to not have to piecemeal several builds worth of info, and wing it.
Ive got over a thousand subscriptions, most of the engine build threads are in there somewhere. But part availability can change like the seasons so i figured current answers were better.
The lower cr pistons don't lower compression that much, and i will probably have to deck the block. Still looking at pistons, not going with KB silvo-lites because of price, and I've heard elsewhere that some were getting sealed power instead or vice-versa. Not wanting less than 19.5:1.. Stock would be fine, or just under. There is a trade off between CR and start-ability, and boosting.
Are you planning on running higher boost levels at all? IMHO there is no point in dropping compression on an engine with stock boost levels. They hold just fine up to 15psi...
Not going to keep the banks turbo for long, or the ip. I might try the db4 hybrid later on though. I'm looking to be able to boost pass 30 psi. Intercooler of course. But turbo and a better ip will wait until the block is done. My current block has poor compression, wont start off ether... I will make a water/methanol kit also. Have the parts sourced but haven't had a need yet.
The cam is not the problem with vibration. Its the older cam gears. The old gear has two drilled and tapped holes in it for ease of removel. The new cam gear does not have these hole
That's right, cam gear... I knew i read something along those lines.. Thanks. I want to get this thing balanced, rotating assembly. I'd be upset if after everything I had a vibration from the gear!
Anything important to tell the machinist? They are reputable but the guy got weird when i said diesel, until i told him it was similar to a bbf - he thought i meant something BIG. Ill send russ a PM, im not in too huge of a rush but would like to swap it in by new years.
Bought this spare block from Plywood about a year ago I think, still willing to help you with your A/C too
Part of the agreement was to build it into something nice
. Heads were off and he said it was out of a farm truck, had ran water for coolant for a while if my memory serves me right. The passages look kinda crappy but I think muratic acid will clean it right up. If it was a 7.3 I'd be more worried about cavi...
__________________________________________
Little back history on my current engine:
po said everything was good, etc. Everything looked decent when i bought it. Ran good, started fine when warm/hot. Glow plugs were mixed brand and crap so i fixed that and went manual control no problem. A few were autolite and champion, bosch, and one other... All came out so i got LUCKY. Starter got weak, batteries weren't holding a charge. Found a trickle charger hidden by driver side headlight. So I got new group 31s, gear reduction starter, 3g 130A alt. Cleaned the wires and no more problem except i found a bunch of waxy crap around the block heater dripping coolant under starter.
Oh great, maybe its the block heater and the ******* tried to seal it over..? Nope. Broke the crap off with a pick, most of it came off real easy. There was a plug rather than a block heater... And a four inch weld.
Started seeing signs that this was an early block from a junkyard - crushed oil pan, grease pen writing on valve cover, etc... He swapped engines. Threw in some stop leak, new rad hoses, added 600w katz hose heater for easier starting. Patch radiator, leak slows / stops.
Good enough. Radiator overflow barb was in bad shape so I tore it out and stuffed a piece of 3/8" copper pipe in, soldered it in and it held. Resurfaced the radiator cap gasket surface too and soldered a pin hole in one of the cores from the fan flinging a rock or tool into it. After that it has held coolant pretty good!
Oh almost forgot when i changed all the filters, there was sand around and past the air filter. In the intake mani there was a little too. Got out all i could reach and did oil change... No wonder compression is crappy. Made me love the idis more though, if a sbc ate sand it would be dead.
This engine still runs good, just eats some oil and hazes, blowby, and doesn't like the cold very much. Last year I had it starting decently with Bosch plugs and new injectors. Then I had air intrusion so I did return lines. A few leaked so I redid them. No leaks except maybe the tee in the back where both sides meet. I think there is an 'olive' there but I haven't had time to tear into it. Could just be oil too from the CDR or turbo (hope its not the turbo seal).
Engine mount on the driver side was shot, one of the two studs were flopping around and the other punched a hole through the plate because it had only a hex-head nut. I swapped that out for a ?king? nut with the rounded base with bumps to dig into it. That kept the engine from flopping around... And I cut off about three inches of some weird metal contraption he had added, I think to "fix" the engine mount issue to the front of the block.
Plus more things than that outside of engine work. But another time
One of the reasons besides those that is prompting me, is that I found oil on some of the glow plugs. Looked like I had dunked them in used oil and pulled them out. 5 & 7 IIRC. Only the top half was "clean"
I'll update with pictures, part #'s as I go
