JeffMoss1
Jeff
oh, also, how do I get the aluminum from the bearing off the hardened ground crank shaft surface? Anyone ever done that before?
thanks a lot for the kind words guys...
I've inspected the caps and it looks like they're all on straight, but not matched up to their correct rods.
Thanks again guys
sle2115 yes i used 30wt oil...is that what you'd use?
I'm exhausted.
Turns out a rod bearing spun. The rest look like they're fine...some very small scuff marks. I bought the plastigage already i'm gonna get to work tomorrow. I think i'll just buy new bearings...i don't think they were too expensive.
Riot warrior...i cleaned all the carbon out of the grooves. I actually have the tool to do it with...believe it or not.
I've inspected the caps and it looks like they're all on straight, but not matched up to their correct rods. Main bearings are good though. I'm gonna go with that being the problem and I'm gonna try and prime the oil system this time.
I'll post a pic of it tomorrow when I'm conscious again. I've been working for like 24 hours straight.
Thanks again guys
If you lose one the whole mess needs to be re-machined.
Jeff, I've seen some rods & caps stamped with a small punch instead of stamped with numbers by previous overhaul person.You could try a strip of exceedingly fine grit wet dry sandpaper looped around the journal and wet it down and run it evenly around the journal kind of like polishing a shoe. and make sure to stop every few strokes to make sure you haven't picked up a big chunk metal polishing compound.
Is there any chance that the rods and caps were stamped with numbers to match them up by someone in a previous rebuild ?
