Agnem said:
Definitely spoken by someone who doesn't know the IDI's well.
So, let me get this straight. These IDIs won't run without gauges, and they run worse if you install a downpipe exhaust without gauges.
That makes absolutely no sense. I can't follow your lack of logic here.
Swany said:
You say that gauges are eye candy but you fancy yourself on having them? That eye candy isn't going to improve performance, it merely lets you gauge where your vehicle is situated. Almost a hypocritical statement if you ask me.
I have gauges because I installed more than just an exhaust and intake. Take a look at my sig, I also have Bean's 160 stage 1 injectors and a TS chip with custom programming suited for the injectors. There is no hypocracy in my statement. I did not tell him not to buy a pyro, I only stated my opinion of when to buy a pyro in the order of mods. And by the way, that's the exact order in which I installed my mods, therefore there is absolutely no hypocracy there at all. And yes, in my opinion gauges are eye candy on a stock truck, especially one that has a 3" downpipe, 4" exhaust, and an open intake.
The Warden said:
Gildo, I must respectfully disagree with you on this point. I am of the opinion that all diesel-powered vehicles should come from the factory with a pyro. A boost gauge is optional on a stock engine (or a lightly modded PSD), but as Mel alluded to, you can get EGT's up to a dangerous level even on a stock engine.
Just my $.02...
The Warden, I can appreciate your opinion about having a pryo, and I agree, it is a good idea. I never said that it wasn't, however, it's a proven fact, that hundreds of thousands of these trucks with IDIs have traveled millions upon millions of miles without gauges. That can't be disputed, with validity anyway. If there were alot of stock IDI engines damaged because of excessive EGTs everyone and his brother would be screaming to the top of their lungs at Ford for a remedy, but the fact is that there is no problem there that requires a remedy. There has never been a recall of these engines for that reason, nor has there been a demand for a recall for that reason, plain and simple.
timntools said:
ok, I agree with getting gauges, but in defense of the lamb amonst wolves, don't you think if the gauges were detrimental to the truck, they would have came with them? If all he's going to do is open up the exhaust some, and he doesn't do anything more with the truck than what the factory specked out, then whats the point? if he's doing what Ford said the truck can do, then he shouldn't be hurting it...right?
Thanks Tim, that's exactly my point. Adding an exhaust, downpipe, and an intake does not warrant the cost of adding gauges, no matter what one's point of view is.
wanderer said:
Been running a chip for about 3 years, with out any gauges. I've got over 5,000 miles with some babies, no gauges. I readily agree that I don't know what the temperatures are while driving. Simple prudence in throttle usage, and a little bit of knowledge of what is happening when you push on it will suffice. My truck weighs 10,320lbs every day. I push her hard, every day. If she blows up tomorrow, you can tell me that y'all told me so.
Oh no! You must be kidding!!!! Your engine actually runs without gauges, but with performance enhancing mods too, and it's been doing it for 3 years!!!!!! It seems that you have committed an unforgiveable sin to some that have responded to this thread.
Agnem said:
PSD's already are equipped with a full set of gauges. It's just that they are not human readable. They are called computer sensors, and it's something the IDI doesn't want or have. Chips are things that get in between the seats and on the floor. To think that Ford didn't put such a thing in because it wasn't needed is to not understand vehicle manufactures.
Definitely spoken by someone who doesn't know the DI's well.
The PSDs are already equipped with a full set of gauges? I can tell you with certainty that mine did not come equipped with a full set of gauges. Please Mr. Agnem, tell me where the stock locations are for the pyro thermalcouple and the sender for the boost gauge on my PSD.
ARGVE said:
Just because it did not come with it from the factory does not mean it's not needed - see that everyday.
That's true. Just because they are available in the aftermarket and because lots of people buy them and then try to talk everyone else into buying them doesn't mean that they are necessary either. I challenge any of you that are trying to flame me to show me with certainly must be vast amounts of stock diesel engines that are blown or otherwise damaged because there was not a pyrometer installed in the passenger compartment. If not having a pyrometer is such a detriment to the life of the engine, where are these engines? This reminds me of the current push for tort reform to reduce the number of frivolous medical malpractice lawsuits, but yet not a single insurance company has produced a single case of a frivolous medical malpractice lawsuit, not a single one.
But back to the original issue that ajd257 (Andrew) was asking about.
ajd257 said:
As of right now, my truck is bone stock, I ordered a DP for it last night and Im ordering the rest of the kit today. The DP is 3" and at the bottom of that I am going to 4". The only gauge I have on my truck now is a Tranny temp gauge, I know alot of people make it seem as though you have to run a pyro if you make any mods, but this exhaust cant do anything but lower the EGTs anyway, right?? My theory is that I have been runnin without a pyro and this can only make it better, so do I really need one?? Also plan to open up the intake shortly.Thanks a lot,
Andrew
I have not seen a single convincing, compelling argument for Andrew to take his hard earned money and spend it on a pyrometer. Yes, I agree that having one makes good sense otherwise I wouldn't have one, and I never said that a person should NOT buy a pyrometer, but how does adding adding a downpipe, exhaust, and an intake warrant Andrew buying a pyrometer?
