DB2 Pump doesn't respond to full throttle
charredsteak
Illinois
First post here, haven't been able to find any threads for this specific issue and none of my buddies can seem to figure it out. Truck ran great up until a couple weeks ago when I pulled the pump out to put new shaft seals in. Doesn't seem like it has full throttle anymore. Took some time to get the timing dialed in, now runs fine at idle to around half throttle and then just stops adding fuel. Also loses all clatter at full throttle. Throttle response is very slow. Added a couple extra flats on the fuel screw, which it didn't respond to either. Ran it for a few seconds with the top cover off just to confirm the metering valve has full travel, which it does. Currently at a loss of ideas. Didn't have the head apart at all when the pump was off, no idea what I could've screwed up.
Clb
Another old truck
nannyfornia
Not trying to discourage you, but...
You need a new pump, look at some stickies.
Factory timing mark is usless once a new pump is put in service.
125k is pretty much the ond of the line.
What literature did you use when you disassembled the pump?
charredsteak
Illinois
Used the factory service manual, currently at 67k but definitely rolled over.
Don't/didn't have any hot or cold start issues but I'll look into it. Already quoted around $400 for a rebuild if that'd cut it
The_Josh_Bear
Western WA
Welcome to the forums!
First thing that comes to mind: have you checked the throttle cable for full travel? It's fairly common for us to have a plastic piece near the IP break off and jam sideways so we don't get full throttle. Pedal travel can also be impeded inside the cab, I'd check there, too.
I'd take off the throttle cable and actuate the throttle arm by hand. Then re-attach and see if it moves the same distance with your hand.
After that you mentioned the timing curve is off, did you change the position of the advance cam on the driver's side? It should generally be right at the foot of the "ramp" on the cam at idle, as soon as the throttle moves it should begin actuating that advance piston. That's generally speaking, the only way to know for sure it's position is on a flow bench, AFAIK. If you didn't change it, that's not the issue...
Beyond that, yes the IP timing factory mark is just for static timing to get it started. Needs dynamic timing, using a pulse meter or luminosity probe. Worth buying one if you plan on keeping the truck a while.
$400 is very low and I'd be suspect of anyone charging that price. There are many more bad rebuilders than good ones. @Old Goat has you covered on the good online rebuilders. I know of a couple more that do the work but don't really advertise, so it IS possible to find good one locally, just do some homework first. The last thing any of us want is to spend $400 on a bad rebuild to turn around and have to spend $800+ on a good rebuild when we could have gotten the good stuff right away without the double downtime. Ask me how I know! :frustrate
I hope you get it sorted out, and happy wrenching!
-Joshua
charredsteak
Illinois
-Joshua
Looked into Russ, most likely gonna send it out there considering y'all's horror stories with local shops.
The face cam was set like you said where it starts to ramp immediately off idle. My understanding is these pumps will naturally add advance as the pump plungers take more of a bite of fuel. It almost seems like the face cam is over-retarding, which wouldn't make any sense.
Also did my best to confirm the throttle cable isn't screwed up. Will check it again. Even working the pump arm manually it seems messed up though.
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
I had a pump that did very similar things. I had it rebuilt by Moose Diesel. I am now a happy IDIer.
REM70
Staff online
