MIDNIGHT RIDER
- Joined
- Sep 29, 2005
- Posts
- 4,666
- Reaction score
- 77
A 6BT Cummins (Dodge/Cummins) will fit in a 1980-1986 Ford like it was made to be there.
Absolutely NO engine or transmission cross-member modifications are necessary, save for cutting the rivets from the transmission member and moving it aft ONE HOLE.
Keep the HUGE Ford radiator.
A bottom hose cross-over will be needed to get the bottom coolant over to the right side.
The only store-bought thing I recommend, unless you are a good fabricator, is a set of known good engine-mounts; having a set that WILL work just saves a lot of head-scratching and working with compound angles.
The Cummins will shoe-horn into the Ford by only removing the hood; I didn't even evacuate the A/C.
I made a bracket, put the 8-rib Dodge pulley on the 1G Ford alternator, and didn't have to change any wiring; since, that is all gone in lieu of a big Leece-Neville.
I sandwiched a "B" V-belt pulley on top of the fan pulley to run my Ford A/C and trailer vacuum.
Don't even bother with the intake heater on the Cummins; it does absolutely nothing that aids starting and is totally un-necessary; it was put there in an effort to reduce cold start emissions.
I currently have four 1st Gen. Cummins trucks and not a one has the heaters connected; they start just as quick, if not quicker, without them.
