Thanks, that's a nice truck he built on the cheap! I wish he woulda figured out the speedo though!
I haven't yet taken time to have a look at the article in question, so what I say may be off base a little.
I puzzled and worried and sat up nights, wondering just how I was going to make the Dodge speedo-sender mate up with my cable-driven Ford speedometer.
There was a speedometer change after the first year of the Dodge/Cummins, the first ones being cable-driven and the later ones having an electronic sensor connected to the speedometer drive.
The later ones until 1994 still got the signal at the transmission or transfer-case.
I don't know this for absolute certain, but having several of both types in the yard, I am almost 100% certain that all that needs be done to convert the electronic units to cable-drive is to un-screw the electronic gizmo and screw on the cable.
The 1989 set-up that I used came factory-equipped with cable-drive, plus I got the Dodge cable.
Still yet, the Dodge speedometer end would not mate to my Ford speedometer.
So, at the easiest location underneath the truck, I clipped in two both the Ford and the Dodge cables.
I trimmed back about three inches of the outer covering from both.
I slid a "sleeve" of close-fitting clear braided hose, 1/2"-I.D. ??I THINK??, long enough to cover the un-covered portions of cable, plus about three-inches of lap at each side.
I pumped as much Kendall L-427 Super-Blu grease into the clear hose as I could manage.
I used a bare 12-AWG BUTT-connecter and crimped and soldered the two cables together.
I then slid the clear braided hose into place and clamped it with plain old hose-clamps.
My speedometer has since performed flawlessly for several years and both the speed and distance travelled are accurate within half-a-percent.
