I hadn't thought of doing that with the studs even though I've done that with bolts many times while replacing them in the truck.
You need to do a write up on this! I’ve thought about doing it myself but it sounds like you’ve had the most experience with it, and know a few good tricks to getting those plugs out.Since you're going to have the heads off, this would be a good time to do the cooling mod in case you ever do decide to install a turbo.
If the head gaskets are not leaking much, and you do want to tackle the replacement of them yourself but when the weather gets warm, consider using a coolant system sealer like Irontite (blue and white bottle iirc.) I know this stuff will seal weeping head gaskets as I used it on my truck before I replaced the head gaskets. Irontite seems to be pretty well regarded and is not "snake oil". This may allow you to continue to use the truck for a while, get to know it, and make sure that this is the truck you wish spend the big money on. It could also buy you some time to acquire the parts, tools and the research time to undertake the project yourself. If you leave the engine in the truck, you MUST have a cherry picker to get those those very heavy heads off and back on again without damaging anything - including yourself. You will also need a good torque wrench. Some will say head studs are overkill, but if you are going that far in and doing that much work, the added expense of head studs is not that bad when you consider the overall cost of the project. As vegas39 mentions above, when the heads are off, it is super easy to R & R the oil cooler, so that is a must do! I don't think the prices the shop is quoting you are out of line at all-but I understand the cost is still painful. Here is a link to the thread I did on my head gasket replacement. https://www.oilburners.net/threads/7-3-head-gasket-replacement-arp-head-stud-install.76304/
