Desertfireguy
So today, I tackled something I've been lazy on, but it brought forth questions. I replaced my fuel pump (lift pump), changed the front brakes, and replaced the vacuum line going to the coffee can reservoir. On the can, there are 2 rubber nipples where the plastic elbow connects to the line from the manifold. There was only one connected, so I didn't do anything but swap the hose. The question is, should there be something else connected to the other nipple? It looks like something is stuck in there, but I cant tell if it's a plug or just a broken elbow. If I need a new can, are they pretty universal. Any brands to avoid?
Hopefully the new fuel pump takes care of the air intrusion I've been getting. Oh on that, I've seen some folks use a section of clear hose. Diameter and type? Thanks in advance!
