I still can't get the charging issues fixed. I see the dash gauge around 8 volts and the battery lite is on. When I run the motor and place a screw driver behind the running alternater its got a good magnetic field at the rear bearing. I was once told this means the alternater is putting out.... I have good continuity from the top of the alternater orange wire to the voltage regulater but still no charge. Bothe batteries show 12.57 volts when the motor is running or not. The alternater is new and just installed about a month ago. I use a mom & pop rebuilder that has never let me down but this may be a first. Any thoughts.....
