vegas39
Hi all. A couple months back, I reported hearing a hissing from my engine after shutoff and losing coolant. I pressure tested the system and had some coolant dripping from the front corner of the head, so for temporary measure, I poured in some Bars leak crap. The loss of coolant briefly went away but then came back. The last few days of driving, I had excessive pressure in the upper hose but not enough to make the overflow bottle bubble. I was probably using a gallon of antifreeze in just a few days of short driving. Other than a little puff of white smoke the last few days, I didnt see any obvious sign of where all the coolant is going.
I pulled the heads the other day and found lots of goopy coolant sludge in the valve covers, I also noticed that the freeze plugs between the intake passages on the driver side head, were pretty corroded and have been leaking. I didnt see any obvious signs of a blown gasket but did notice that both gaskets looked pretty tired in a couple areas. I also noticed some drops of coolant down around the lifters after I removed the valley pan but I think that may have come from the corroded freeze plugs in the head.
Now that the heads are off, is there any way I can check the cylinders for cavitation problems? Although this truck has never been an extremely fast cranker in the morning, I've never had a problem with the starter acting like it was fighting an internal issue. I'm hoping my problem is just head gaskets but I want to be sure before I drop several hundred bucks for nothing. Thanks.
