Can you guys tell me about my new 6.9
Slicknik
Burbank, CA
Post a photo of the trans , when fords switch between owners who knows what’s under the hood,( @IDIBRONCO is rt tho)
7 psi on a first gen banks , non wastegated/no inner cooler sounds right at 3k. It’s a conservative setup , wouldn’t go any higher without head studs or atleast checking your timing and a compression test
Remember your 21.5 to 1 and you have one less head stud per cylinder than a 7.3 idi
If your gonna go up a flat or 2 better make sure your brakes are up to par, also take that 30 lb air filter lid off and see how dirty that filter is....
Good lookin truck and engine bay
Thewespaul
Bulverde, Texas
Well an intercooler allows you to run more boost, you typically see less boost with an intercooler because of the cooler air charge.
6.9 and 7.3s both have the same amount of head bolts, and they do not have studs from the factory, but it is a common upgrade to increase clamping force on the head gasket. 6.9s use a smaller fastener, and consequently can run less boost than the 7.3s.
Slicknik
Burbank, CA
@Thewespaul , learn something new every day, I thought they had one less bolt , I knew they were smaller in DiA, but a dogg none the less
ttman4
Last Nite's Dream..
I think ill stick around here this forum is cool
We all think so too. We also try to keep it that way.:Thumbs Up
Of all the forums I'm members of this one is the best!!! Very informative, no bullying, no dumb question, helpful, humorous, tons of tec articles, etc, etc
Just wish I had the hours to look & research....
But mostly as IDIBRONCO said "We also try to keep it that way"!
James
Buffetkiller
Washington
I just keep this one going to not clog up the front page. What does yourguys oil pressure sit at? Mine is a tick below normal. Ive read other guys say dont trust them. Im wanting to put a oil pressure gauge in cause i have a third hole for one
chillman88
Central NY
The stock oil pressure gauge is literally a dummy gauge, they aren't wired to work "correctly" they basically turn on when you have any oil pressure and off when you don't.
Get a real gauge
Buffetkiller
Washington
OK. Do these have low oil pressure light? And what gauges do people usually buy? I don’t want to cheap one but I don’t want to spend $250 on a little POD gauge
Knuckledragger
Payson, AZ
Don't worry about low pressure, there are 8 cooling jets that act as a constant leak, so it does not get too high. Volume is king in these engines, that is why you need 2 1/2 gallons of oil to fill them up.
As long as you have 10 PSI for every 1000 RPM that you engine's turning, you're fine. In theory, all you need at governor speed is about 35 PSI. Unless your governor's been turned up.
Yes. You can buy a quality, aftermarket electric gauge that only has a wire going inside the cab.
tke395
