Having worked for many years in a machine shop, I can tell you that they don't (and really can't) check valves for stress cracks. What they can check if for bent or burnt valves and that's just done by experience. Bent will also show up when you face the valves and they are chucked and spun against a grinding wheel.
As far as recourse...my degree is in business management, I've run several auto related businesses, parts store, machine shop, three different garages, etc. If you were my customer, I would assess the damage, and if I felt (and believe me, I'm fair, but not all machine shops are) the shop had ANY involvement in the cause of this, I would repair the issue, and at least cut you a deal on the gaskets, etc. It's kind of hard to tell from here, but if the failure was totally my shops fault, I would take care of it.
There is an adage in business, and I'm sure that Diesel Care is quite aware of it thus the aggravation with our "list", and that is one happy customer will tell/recommend you to a friend, one unhappy customer will tell everyone who'll listen...that adage is very true and can/has caused many a business to lose customers. Now, with that being said, if you came in demanding I give you everything and then some, you're not going to get anywhere. So, if you find it is an issue, go in with an open mind and calm temper, tell them there is an issue you feel is possibly at least somewhat their fault. I'm kind of wondering about the shop you used because of the surfacing, etc. I would also recommend this to ANYONE going to have head machined, when you take them in, ask about minimum thickness and the setup of the precups...if they don't seem to know what you are talking about, I'd load up my heads and go elsewhere. ANYONE who's done diesel headwork has dealt with pre-cups and has the tools to cut them and their seats. We had a very fine diamond cutter that we used to resurface the combustion side face of the pre-cups.
Anyway, good luck with it all.
