Yeah a lot of people don't understand just how much time and work goes into something so small and "simple". Those rails R&D makes sounded expensive until I thought about the man hours that go into them!
I'm not so sure about that. The older I get, the easier it is to forget.Getting old and forgetful, is not easy.![]()
Agreed! But it is something I'd have to budget for, for a while.IMO, those would be a steal at $250 for just the caps. Hose is cheap and can be found anywhere so I personally wouldn't care if the "soft parts" were not included for that amount. Personally I think these would be a better solution than the fuel rails previously mentioned. They just seem more fool proof.
Having said all that, I still have yet to change the caps on my truck. Someone did before I got it because they aren't grey, but 15 years later I changed the O-rings two or three times and that's about it.
I agree here, once I got Viton O rings and used grease to install them I haven't had much in the way of air issues and certainly no leaks.
Finish off the air intrusion issue with a proper check valve between fuel pump and filter header and you've got yourself a setup that won't let you down.
They aren't shiny like the brass ones though...![]()
There's many other parts that will run out of availability sooner than the plastic return line caps would, like much of the fuel injection parts which are out of production now, my return caps are made here in the usa by delphi and they dont plan on slowing down production anytime soon since its still a good seller for them. The brass caps will be sweet too!
In my opinion the hose nipple needs to be a single bump, getting old hard hose off of that barb is not fun, and when they get nicked by the knife that will be used they could leak.
BTDT
Those all have the single bump that Russ was talking about. The brass caps have the barbed ends on them that make it next to impossible to remove old, stiff rubber hoses without cutting them. I have to agree with Russ on this one.
