Working on replacing the 31 year old awful hydraulic hose type fuel lines on my 94 GMC with standard 3/8 and 5/16 hose, I had to do a lot of research for fittings. GM could have used regular fuel hose but NoOoOoO they put special hoses you had to get from GM. And now they're NLA. I really despise GM.
Anyway, I came across this fitting, M16-1.50 with O-ring (what GM used for fuel supply lines) to 3/8" hose barb. Dorman 800-170
I ordered one to patch in between the fuel sending unit/pump and the fuel filter, but one could use it for an in line fuel filter setup for IDIs if you want one for some reason, using cheap common metal GM filters. The filter is female on both sides, so two of these and a filter gives you 3/8 hose barbs on both sides.
Example filter: https://www.autozone.com/filters-and-pcv/fuel-filter/p/valucraft-fuel-filter-v3504/822268_0_0
They're on rockauto for cheaper. Look up a mid 90s GM truck with 5.7/350 to find them easily.
The Viton o-rings are in kit # 800-013 (it'll have the 5/16 ones also) if you need replacements.
Maybe that'll be helpful for someone wanting an easy to replace in line fuel filter with 3/8" hose barbs.
