When I apply the brakes the pedal is kinda soft. I can pump them and get them firm but as I hold the pedal it slowly goes soft. Truck still stops fine just has a softer pedal them I'd like ? Thank you for any help.
I just went through all of that and still have the soft pedal.
I replaced every single part in the brake system except the vac. pump and the booster.
I bled about a gallon and a half of brake fluid through the system and still no better.
Hope you find a solution. I f you do please post it up.
