Hello, i have a 1992 F250 with a 7.3 idi and a E4OD transmission 2wd, and since i have the truck (almost a year now) i find that it doesn’t brake hard, brake fluid has been changed, the hard lines on the rear diff too, front calipers work as they should and no leaks, also no air, brake light is off, but i hear a small hiss when pressing the brake pedal, since i have the truck too, tought it was normal, if you have an idea what can be the problem i’ll gladly listen!
