RSchanz
I've replaced the front calipers and pads, new master cyl and new brake booster. Now the brakes need to be bled.
I've got a trailer brake that I don't use and I'd like to remove. Is it as simple as just disconnecting the brake line that goes to it and unplugging and caping the wires?
In terms of bleeding the brakes, I kept the old master cyl top in order to make one of these at home bleeder add on things seen on this write up. I guess due to the metering valve this entire process is a bit more of a PITA than it should be? Is this linked write up overkill, is there an easier way to go about this where I don't need to attached an adapter on the old master cyl top?
