Kdo58
My emergency brake pedal does not ratchet, can this be repaired or do I need to go to a wrecking yard?
I 2nd that. In my case, it took a good cleaning and some silckum ... it was packed with cr*p!I've had that happen before, ratchet mechanism just needs some lube and worked free.
I'd consider removal, CLEAN, and lube with "X".trying to figure out where it holds up so that I can try lubing the right area.
I've done the front (primary) cable once.So... is it difficult to unbolt the parking brake assembly to clean/lube and install a new front cable?
You're killing me with the word "neophyte" ... just say novice!I've done the front (primary) cable once.
I remember that it was a "whippin'"...but I was a neophyte... someone with more experience with certainly chime in.
Neophyte!You're killing me with the word "neophyte" ... just say novice!
You just said a mouthful!Im plumb tuckered out and a bit of a neophyte, to look into the full lexicon of the engish tongue.
