Booyah45828
You're right, flow and pressure aren't the same. But they are directly related. Pressure is the resistance to flow. So if you're supply pressure is at the correct psi when the engine is fully loaded, then the fuel flow from the pump is adequate.
I guess I assumed your 4.5-5 psi figure was measured when you were having your power issue.
Figure out what your fuel pressure is when it has the low power and then go from there. Once you have that, you can then make a plan.
Did all the people who had the facet pumps and low pressure have power issues too? I don't remember.
