Well thanks for the help everyone. I'm done for the moment. Here is what I did. I removed the factory alternator, which I think is in the 70 to 85 range, and replaced it with a new in the box, but at least 5 year old Lestek 135 amp marine rated jobby. It has a slightly smaller pulley than stock, so it should spin a bit faster, which makes me happy. I had to make a 1" spacer for the bottom bolt, since the Lestek casting had a 2" instead of 3" sleeve. Other than that, it bolted right up. I had to cut off my field and stator push button connectors, and replace them with female spade types. I completely removed the factory 10 guage wire, so I could track down the wires to the alternator gauge on the dash. For those of you who don't know, the 80-86 trucks had alt gauges, not volt meters, and they rarely moved at all. That 10gauge wire only needs to go a couple of feet to get the job done, but because of the amp meter being a shunt type, they wind the wire through the wiring harness a total of about 4 feet, so there is enough voltage loss to measure. I then replaced the 10 guage with a 4 gauge that I used crimp on ends with, that I then heat shrinked over. I changed some of the wiring around and made the alternator gauge connections with ring terminals at various points, and adjusted the total length of the wire run, so I now see some needle movement which is an improvement over before. I eliminated the fusable link, and will revisit the idea of a fuse or breaker at some point. I'm using a 10 gauge like the original to power the wire harness at the factory point, but I have more circuits that should be moved over, and I will increase the size when I do that. For now, the alt is capable of feeding the batteries full capacity, and when I hook up the electric fans, I'll feed them from that branch. Pics will come when the fans get done.
