Adjusting Fuel Screw on DB2 pumps with pics
Dieselcrawler
Professional wrench holder
Quakertown Pa
Step by step on how to turn up or down your fuel screw. ***DISCLAIMER*** WE DO NOT RECOMMEND ADJUSTING THIS SCREW WITHOUT THE ADDITION OF A PYROMETER! THE IH 6.9/7.3 ENGINE RUN WARM IN STOCK FORM. TURNING UP THIS SCREW CAN CAUSE ENGINE FAILURE DUE TO EXCESSIVE EGT.
Please unhook battery cables prior to starting this so there is no chance of engine turning over by accident.
first remove the oil fill or gear cover from this location.
u will see this
bring the stud around till it is at the 12 oclock postition like this. use a 15/16th socket on the harmonic balancer bolt to turn over.
find the little triangle cover on the pass side of the pump and remove. dont damage the gasket. a pint or so of fuel will come out. place a rag or 2 under the pump to catch it all.you can use any rag, doesnt need to have sheep on it, just heard ron likes sheep...it will look like this
inside that hole is the adjusting screw. if the pin on the front of the engine is at 12 oclock, the screw will be visible with a mirror. will look like this.
closer veiw.
turn that screw clockwise to increase fuel. counterclock wise to decrease fuel. screw is a 5/32 allen.
John Deere
Wyoming
That's a great post, I had not thought of taking the filler neck off to use the dowel pin as screw locator.
Hydro-idi
Lodi, California
Very nice write-up. I have a feeling that lots of people will be fiddling with their IP's in the near future :sly. Good job on the pictures as well
One thing I feel is an overlooked point is that plate to access the alen screw must be cleaned off BEFORE you remove it. Use brakeclean and an old tooth brush but get it clean... Any dirt that gets in the cover area will ruin the pump. So cleanlyness is next to.....:sly:angel:
Devon Harley
San Diego
nice write up i just bump the sil an stick the allen in an out an takes maybe 5 trys but that looks alot easier.
subway
be nice to the admin :D
York PA
Nice write up!
now we need a mod to change Rons name to DSLsheepcatcher :D
hesutton
The Anti-Anderson
Bowling Green, KY
Are we implying that Ron likes mutton sandwiches/chops/BBQ................... or that Ron really, really, likes sheep?:D
Heath
saburai
Thanks Corey :cheers:
I'm assuming that the filler neck/gear cover was originally equipped with an O ring since there's a groove. On my truck it was glued down with black RTV. Unless it's a standard size that I can source local atime the auto parts or hardware, I guess that's how it's going back on.
