6.9poweredscout
Bleeds IH red...
my carpet fits fine from my auto-zf swap.
now you're going to hear the east coast guys howl about a reg cab truck getting killed for parts.
I just imported the whole truck from Oregon.
Liar! Still have the clutch hydro assembly to pull out.
He mentioned to me that they were held in by the brake booster fasteners alone.
I hope you have a strong engine. My truck has a zf with 4.10's and 35 inch tires, and it barely turns over at speed. I don't know how hilly it is in Oregon, but here I barely make it up and down the hills around here empty in overdrive. I guess it would be ok if you never used the overdrive in 5th gear.
I think I would swap the zf in first by itself and try it out. And then add the other overdrive later if you though you needed it. My truck originally had the c6, and I was getting 12mpg. I swapped the zf in place, and with no other mods, I am now getting 15 mpg. So your torque convertor slip you have now might be that 1 mpg difference.
