Damn I got double screwed today. Went to swap in what I thought was the correct pedal assembly after my discovery on Saturday from towcat's comment. Things didn't go so well. Once I had the dash torn apart and steering column pulled I set the Auto-Pedal assembly next to what I thought were 87-91 Manual-Pedals.
No such luck, the spacing for the bracket that bolts to the column as well as where the pedals bolt to the dash is different....I barreled ahead anyway thinking I could "make them work". No such luck...besides the mounting hole spacing difference, I was unable to connect the ignition switch once I re-installed the column.
So out everything came and went back in with the stock stuff. After 3-4 hours I was right back where I started. I'm thinking I actually have a set of 83-86 Bullnose pedals and a set of OBS pedals. Anyone have a picture of the 87-91 pedals I can use as a comparison? Meanwhile I'm off to find another parts truck
