87 Crew Cab w/ 6 doors
Those caddy calipers are larger than most car calipers. Someone on FSB did a clamping force/surface area comparison against the front dial passion calipers and the results weren't far off. Not sure if they'd be viable for heavy hauling, but IIRC, the heaviest thing the 6 door will see is his boat.
12k pounds. my big boat is a heavy *******.
it did ok with drum,
im anxious to see how it will do.
the trailer is a 3 axle w/ disc brakes.
F350camper
BOOST!
USA
going down a long grade hauling heavy against compression, having to tap the brakes now and again to keep speed in check, I'll take the disc's on all four corners. OTOH, a perfectly tuned truck drum setup is hard to beat in a fully loaded panic stop situation.
most of the action will be that of a real mans mini van LOL
taking kids places with no load.
only once in a while it will tow the big boat.
most of the time its the little 2500 pound flattys
and ill be building a PSD next so most likely well take that one on long boating trips.
i cut out the holes for the gauges, but it didnt fit. the front of the gauges are golden, but the retainers did not work.
the guges i have coming are a different mounting style, hopefully i can make it fit.
Could ya back up a bit further a d maybe shine some bright light on the panel before ya take anymore pictures? Would help us have another reason to give ya a hard time ;Poke
for you Al
I found what you can do with the psd van. Lol
Here's the thread on it. http://www.ford-trucks.com/forums/1357508-1999-7-3-van-build-thread.html
wow, thanks for sharing!!
but uahhhh that thing IMO is hideous!
the van is the last thing on my mind.
but i would like to find some coil sprung axles and a ZF for it.
or just use my divorced transfer.
too many projects, not enough time.
thinking about taking a break from diesels to finish up some other projects on my list.
but the 87 must be done first.
Clb
Another old truck
nannyfornia
