I picked one up for the rear. I was thinking about painting it and then polishing the fins or at least removing the paint. Did you get the ford superduty rear? Where did you get the front? I'd like to have something nicer up there but I may end up just nickel plating mine.
i smell a "not as described" return lol
I wonder why they could not just put the whole axle in the truck. Is the van track width that far off?Rear Brakes: http://www.fordmann.com/F350.rear_disc_brakes.htm
I'd like to see you do something like this. Everything is there in that article, just need to find you a junk E350 with the full floater Dana 60 rear!
Spring perches are easy to do. I have done them several times. My truck is sporting 3.55 so finding my gear ratio would probably not be hard. I know that is not the case for everyone.You could, but you'd be downgrading axle ratings from a 10.25 to a Dana 60. Also work including perches, driveshaft etc? maybe Gear ratios as well I'd guess.. Are there many 4.10 vans?
